跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 个问题 查看全部
2012 MBP Parts Swap
So I have two partially broken 15inch Macbook Pro's, an A1286 2011 and an A1286 2012, The 2011 has an Anti-Glare Screen but a bad motherboard, and the 2012 good logic board with the 1gb of vram, but has a damaged screen and trackpad. I just wanted to know if it was possible to take the screen and trackpad from the 2011 and put them into the 2012?
I was told that screen connectors might be different and I may have to mod the cable?
Has anyone tried this, is it doable? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hey there! I have good news! The trackpad and display are both totally interchangeable. The cables on the display are even the same. The only difference between the two displays is that the 2012 has a better webcam.
Best of luck in your repair!
这个答案有帮助吗?
得分 1
1条评论:
The display connector on a 2012 is slightly different, you may have to bend the one on your logic board. 100% works though!
完成的
添加一条评论
添加你的答案
Dontae 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 196
