跳转到主内容
Second version of the Beats pill. Sold by Apple in California. Released in 2013. Model number: BO513.
Why won't my pill charge?
All of a sudden my pill won't charge,I didn't drop it nor is it damaged.Can you help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
The battery has 4cables in a block connected to the circuit board pull this block out of the circuit board then reconnect. I'm pretty sure mine had just vibrated loose,beats pill worked straight away and taking a charge.
完成的
添加一条评论
2个答案
已选择的解决方案
Here's how to get into it. Look for the number on the battery:
https://www.youtube.com/watch?v=Jh3VWvA3...
这个答案有帮助吗?
得分 5
1条评论:
I have met the same problem, my beats pill 2.0 won‘t charge and out of warranty. After watching this video, i bought a replacement battery from amazon and replaced it by myself, it works great. Thank you. The battery's ASIN is B01MXDCSXT, you can search it on Amazon.
完成的
添加一条评论
most likely, the battery has gone bad.
i am searching for one myself, but its starting to seem that you have to send it back to apple for battery repair\replace..
Update (12/04/2019)
just to add a bit.. you will also need to be comfortable soldering and unsoldering the battery leads.
if you can do that, should be a fun project.
这个答案有帮助吗?
得分 3
5条评论:
after some digging, i found that the pill takes 2 batteries and are almost the exact same size as a gopro hero 2 battery. you have to take the cover off the gopro battery to get it to fit, but it will work.
you do need to be comfortable with taking apart small parts and possibly modifying the case a tiny tiny bit to get it to fit, but it does work..
完成的
Does it Cost money if you send it back for a battery replacement
完成的
Send it and let us know if they do it for free...
完成的
Only if it is out of warranty
完成的
How much does it costs if it's out of warranty?
完成的
添加一条评论
添加你的答案
Joe Wright 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 37
总计 40,115
