跳转到主内容
Repair information for standalone freezers.
197 个问题 查看全部
Why is my upright freezer leaking a "lot" of water from underneath?
My upright freezer is leaking a "lot" of water from the bottom! I don't think it is quite as cold as it usually is, but the food is still frozen. I hear a noise, but not sure if it is just a fan, or motor, or compressor. Don't think it sounds as it normally does. The water covered my entire garage floor...I can feel cool air coming out the vents on the inside, but the foggy stuff isn't circulating.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Cause 1
Clogged or Freezing Defrost Drain
During the freezer’s defrost cycle, the defrost water exits through the defrost drain. Sometimes, the defrost water can freeze over the drain. If the defrost drain is clogged with ice, the defrost water will overflow the drain and leak from the bottom of the freezer. To thaw the ice inside the defrost drain, use a turkey baster and hot water to flush the drain. If your defrost drain freezes regularly, consider installing a drain heater to melt the ice.
Where do you live an how cold is it in your garage?
这个答案有帮助吗?
得分 8
1条评论:
It is not in garage but in the basement, which is set at 68F. Ontario, Canada
完成的
添加一条评论
my door was lift open by mistake none it will not freeze all the can you please help.
这个答案有帮助吗?
得分 0
2条评论:
my freezer leaks from underneath ive told my new landlord but he just says thats what happens its about 6 yrs old it never did that before
完成的
my freezer is leaking from bottom my new landlord says its ok thats what happens but it has never done that before its 6 years old
完成的
添加一条评论
添加你的答案
gracie1rda 将永远感激不已
浏览统计数据:
过去 24 小时: 23
过去 7 天: 110
过去 30 天: 543
总计 53,275
