Not washing all the plates etc
Can anyone help the dishwasher is only cleaning half of the plates bowls etc that are in it to be cleaned they are rinsed before hand and the dishwasher tablet has gone
Hi Jayne
I sounds to me like the spray arm might be clogged.
Check a few things...
1. Clean Sprayer arms.
usually, you can unscrew/remove the 2 spray arms, from the middle. remove them both, and check if something is inside (sometimes its seeds, from food or something). the little sprayer holes often get clogged up, and they no longer spray properly.
2. Secondly, the sprayer arm in the top tray, seals onto the pump at the back of the machine usually when you push the tray to the back, and close the door. Check that the little rubber seal is still there, and sealing properly. if this doesnt seal, it doesnt have enough pressure to get the top sprayer arm to spin and spray properly.
3. its also possible that limescale has clogged the internal pipework, making it really hard for the pump, to get a decent spray going for the cleaning, usually, this is caused by living in a hard water area, and not putting salt in the dishwasher.
4. lastly, the pump might be failing, and the motor turning too slow to get a good amount of pressure.
I would suggest making sure all the sprayer arms were clean, and also clean the food trap at the bottom of the machine. then get a good dishwasher cleaner (https://www.finish.co.uk/products/perfor... ) and make sure there is enough salt in the machine.
If none of these things help, then im afraid you might need to get a professional to take a look.
Or.... if you fancy yourself a tinkerer.... take it apar, and create a teardown for your dishwasher :)
Regards
Ian
这个答案有帮助吗?
Really excellent answer!
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 43
1条评论
What do you mean, "the dishwater tablet has gone"? What half and where are the plates that are not getting cleaned?
由 mayer 完成的
