跳转到主内容
加入维修社区 - 创建账户
佳能 EOS Rebel T3i 于 2011 年 3 月发布,可以通过其 SKU (SKU:5169BO32) 来识别。这款相机也被称为 EOS 600D 和 EOS Kiss X5,是一款具有1800万像素的佳能数码单反相机。
Camera won't turn on
I was using my canon 600d camera and suddenly it just died, I mean turned off by itself.. I presumed it was the battery so I fully charged it. Unfortunatley it is still not turning on. Any solutions for this?Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
make sure the media card slot door is closed and secure properly..there are points on the door that go into a slot when the door closes and triggers the camera to know its closed..the camera will not turn on if the door is open or not closed properly..
由完成的 分享
添加一条评论
3个答案
I have the same problem , i checked it and the dc board ( Power board ) has broken
这个答案有帮助吗?
得分 0
添加一条评论
My issue was a corrupt SD card. Try removing your SD card first and power on your camera. This worked for me.
这个答案有帮助吗?
得分 0
添加一条评论
There are also small tabs on the CF card door and the battery door that depresses a switch when closed. On my camera, this tab was broken off and no longer pressed the switch. The parts are small and not obvious but will keep the camera from turning on if they are missing (broken).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
michaelmusong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 36
总计 2,628
