Why won't my washer drain and then spin.
hi
Washer is full of water and top panel controls will turn on and off to add more water but washer won't drain or spin.
So there is power. And I checked to see if the exit tube was blocked but I was able to drain the washer tub simply by using gravity...thus draining the water into a bucket. So the tube is not blocked.
Is it a control dial problem, a water level sensor issue, a pump problem or who knows what?
