跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
Update file corrupted su-30645-8 on usb with new hard drive.
I got this PS4 from someone. It didn't come with a hard drive he told me it would not take updates via usb. I installed a new hard drive tried 10 different thumb drives and about 5 different hard drives. Still get the same error; I have been using the big update file for new hard drive installations.
I have also tried fat32 and exfat I saw somewhere on the forum where someone said the size needed to be below 4kb so I tried as well when formatting along with full formats. The update need to be 2.50 and above so I have tried every update from 2.50 up to 3.50.
I've seen people with brand new consoles have the same issues. They got a new hard drive to get the same error and they have tried the original hard drive to also get the same error.
Does anyone have any suggestions on what it might be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
So just to be clear... What is the exact error code?
(P.S. Picture would be nice if one is not listed)
完成的
@ethreal1 The error code appears to be SU-30645-8.
完成的
添加一条评论
12个答案
最有帮助的答案
I had the exact same problem after trying a million different configurations, turns out it all boiled down to the browser i was using to download the ps4update.pup - i was using ie and instead tried chrome browser. I would give this a shot
这个答案有帮助吗?
得分 3
7条评论:
I had the exact same problem please help
完成的
chrome is not it.
完成的
Guys use google chrome it worked for me it just did
完成的
Bro thank you so much youre the real G
完成的
I used chrome and ie to download file but I get nothing
完成的
显示更多的2条评论
添加一条评论
it;s a hadware problem on the motherboard. i am trying to figure it out for 2 months. i have replaced the processor and syscon/nor with a working one and it's still the same issue. i have moved the original chips to a good board and it works. so don't bother anymore unless you do smd rework
Update (08/30/2016)
I have cracked this issue. The problem is hardware related, more exactly ram related. When you want to update the software, first the console copies it into ram an then it writes it. If a ram module is fulty it will mess up the file at binary level, so in conclusion the md5 will be different so the ps4 reports the file as corrupted. The only way to fix this issue is to replace the faulty ddr5 module/s. Unfortunately, unless you see any phisical damage, there is no way to determine which of them is faulty so you have to replace them one by one. I auggest starting with the ones on the back. Warning: unless you have professional equipment and necessary skills, do not attempt this on your own, because you may cause irreversible damage
Update (12/24/2018)
I can see some people had this issue and in their case the update file got corrupted while downloading, copying it to usb etc. make sure that you check the md5 once the file is on the usb drive. If the md5 is intact and you still get this issue no matter what, its probably a hardware problem, ram related as i said before. I own a playstation repair shop and i do repairs daily. I fixed this issue quite a few times until now by ram replacement. Sometimes the console was showing some white or red dotted artifacts as well. Unfortunately there is no way to find out which ram block is faulty unless there it has some phishical damage. So you just have to replace them one at the time or how i like do do it, one side of the board at a time
这个答案有帮助吗?
得分 2
2条评论:
Thank you for the feed back. I'll find out where I can get some ram modules from and go to work. I have all the necessary equipment. Thanks
完成的
was not my issue.
完成的
添加一条评论
Found the issue! When you go to https://www.playstation.com/en-us/suppor... there are 2 options: Update from PC and Reinstall from PC (this is at the bottom) use the download link for the reinstall, the file is 849mb in size, if you get 297mb its the wrong file and will give you the error. I had to use IE11 to download it, Firefox only ever pulled the 297. Happy gaming!
这个答案有帮助吗?
得分 2
1条评论:
This works for me. Thanks!
完成的
添加一条评论
ite so after reading through countless forums and numerous attempts at trying to get get the usb to work i think i finally got a solution! so i formatted my usb to FET32 and unchecked the “fast format” box. afterwards i re-downloaded the system files using IE ( i used chrome every other time) and replaced the .PUP file in my usb with the new one i’d just downloaded. then connected the USB to the front of my ps4 n it worked. hope this can help someone else.
这个答案有帮助吗?
得分 1
添加一条评论
I don't remember ware it is but there is a way to just "wright" the HDD before you put it into the PS4 look in the forms on sonys website and such also I believe you can clone a drive from another PS4 if there is nothing on it. (Don't quite me on that)
这个答案有帮助吗?
得分 0
添加一条评论
I can do smd work so if you find the reason on the board can you please let me know.
Thanks
这个答案有帮助吗?
得分 0
1条评论:
I did, read my updated answer above
完成的
添加一条评论
S O L V E D
Good morning , fellow,
I had the same issue, i solved it by assembling the pen drive as show at the Plastation web-site, a followed exactly the instructions of the Playstation web-site , BUT be sure to use REAR USB PORT of the playstation to upgrade your video-game, the front usb port wont work for this issue.
Good Luck,
这个答案有帮助吗?
得分 0
添加一条评论
I've tried every update type / install guide possible. Best I can do is start in safemode, dowload update(which already has been downloaded multiple times) and get a few hours maybe of gaming before a big loop of errors and problems reading USB file for update. I honestly just want to get it to where I can sell it to a retail outlet at this point. Please any help is appreciated!
这个答案有帮助吗?
得分 0
添加一条评论
Its nothing just download it using chrome and update theough usb no other browser.
这个答案有帮助吗?
得分 0
添加一条评论
Solved it by reformating the usb drive without the fast format option; then I followed instructions on the Sony page. I don’t know if it makes sense. I was using a brand new Kingston Datatraveler 100.
这个答案有帮助吗?
得分 0
添加一条评论
I found an answer to this issue for myself.
I bought a 480gb kingston ssd to upgrade my ps4. After arriving i installed it into my system and attempted to inistialise with the correct file from sony.
Error after error after trying each and every solution on this page and many others.
TURNS OUT I JUST HAD TO FORMAT THE DRIVE TO FAT BEFORE INSTALLING IT INTO THE PS4.
An uninitialised drive with give the error is my hypothesis.
Thanks
这个答案有帮助吗?
得分 0
1条评论:
I have the same issue, is your ps4 still working ?
完成的
添加一条评论
hello
i solved it
just change your router
or change your NAT types:)
这个答案有帮助吗?
得分 -1
1条评论:
Changing NAT type won’t solve that.....
完成的
添加一条评论
添加你的答案
Jon 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 52
总计 25,273
