跳转到主内容
MacBook Pro 13寸显示器版本
9745 个问题 查看全部
问题已关闭
No video, no audio, but lights and sound
I have been using my macbook for about 3 years. No problems. One time the LCD hinge broke but I fixed that myself after ordering the part...basically had to take every part of the macbook apart... fun stuff actually!
I say all that to say I am 100% comfortable working inside my macbook.
Having said all of that, my macbook fell off a bedside table onto my bedroom floor... I think the back left corner hit first.
It was on at the time.
Video went dead after that.
Now, when I turn it on, you hear all the gears moving, but where you typically hear the startup tones, you hear nothing.
And, no video.
But the status light stays lit up.
Any suggestions?
Sorry if this is in the wrong group. Please suggest another one and I will happily move it.
thanks in advance
J
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Reseated HD and RAM. Tested each invididual RAM stick in each slot in case a slot or a stick was bad... no dice.
WIll have to find a VGA adapter for this macbook since it doesnt have VGA.
...and what if i cant find my install disk...? :(
完成的
添加一条评论
2个答案
已选择的解决方案
Reseat the RAM
it could have jumped out of the sockets... If thats not it Boot from your install disk and run Tools->Disk Utility->Disk First Aid->Repair disk.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Hook it up to an external monitor to check the display package. You can also start it up it Target Mode using another Mac. Start up holding down the "T" key and have it plugged into another mac via a firewire cable. The hard drive icon should appear on the other mac and you can run disk utilities on it.
这个答案有帮助吗?
得分 2
1条评论:
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 1,821
