跳转到主内容
在2015年3月发布,于2015年4月10日开放购买,Galaxy S6 Edge是Samsung最新的旗舰智能手机的曲面屏幕版。
237 个问题 查看全部
s6 locked to overheat mode
my s6 got drowned halfway under water. after that phone has locked to overheating state so it wont allow to charge battery. i took the phone to service and they tested the battery and said its fine BUT they said motherboard is faulty. What should i do? i really want to fix this phone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
mine to..it happend during a rainy day..twas not soaked wet..maybe moist.. now whenever i charge the phone it shows a triangle and a thermometer in it and a beep.,,tried recovery, odin, clear cache.. failed.. last resort i buried s6 in rice.. dunno if it will work..
完成的
ronaldoguerrero rest assured that rice is not going to do anything. Rice is not a tool and placing your phone in rice is the equivalent of doing nothing. Unless you disassemble your phone, clean it properly with high grade isopropyl alcohol and replace the battery, your phone will remain defunct
完成的
添加一条评论
1个答案
最有帮助的答案
You need to have your phone put up through a water treatment by a reputable repair company. I'm guessing whoever you took it to didn't even bother to take the phone apart right? The Edge can be tricky to disassemble, but it's going to have to be done. After it's been completely disassembled, the motherboard needs to be run through whats called a sonic cleaner. After that's done, the phone can be reassembled and tested for any other parts that may have been damaged by the water. Not a bad idea to replace the idea out of caution after water damage, even if it seems ok. Your overheating message is often the result of a short on the charging port cable caused by the water exposure. With the right technician, I'd say there's a very good chance your phone can be saved
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Miro Harri 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 889
