跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone 6 Screen Replacement Light Leakage
So i've now gone through 2 replacements of the complete assembly (minus touch id) from different suppliers and I am onto a 3rd, however consistently, there is a small gap of light leaking from the mute slider and there is a visible raise when compared to an original.
Almost certain the phone isn't bent as an original screen doesn't have this issue.
Is there any way to fix this with a small amount of adhesive or anything else? I have reseated it a couple of times to the same result.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Lewis,
I have seen this on a few iPhone 6 screens. The housing is completely straight. Right?
It really shows up on the black iPhone 6. I open it back up and on that side run a piece of black electrician's tape to overlap the back light. It has to be right at the top to about half way down the screen. Trashy I know- but it works and have never had one come back.
Other option is you can pay to send the screen back and they will send you another one with the same problem.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Get a good quality screen from a different supplier. These screens will soon lift from their frame.
Alternatively place a strip of black tape on the edge of the LCD (inside) to cover the side that leaks light to the outside. Originals have this piece of tape.
这个答案有帮助吗?
得分 4
添加一条评论
I've been using the tape fix but it still doesn't answer why it's happening. I've bought OEM products and it still happens.
这个答案有帮助吗?
得分 0
1条评论:
Bent housing can cause this too.
完成的
添加一条评论
添加你的答案
Lewis Watson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 8
总计 7,946
