跳转到主内容
MacBook Pro带有15寸屏幕的型号
8256 个问题 查看全部
Black Screen when starting the device
Hey guys,
I have an almost 3 years old macbook pro. Since two months the screen stays black when starting the computer. I know the computer is running because I hear the sound and I can see my desktop when using an "external" display.
Additionally I know that the screen actually does work because when I start the computer I can see a white screen and then the apple sign...afterwards it turns black.
I've brought it to the mac store but they didn't find out what the problem is (probably wanted to sell a new one to me, but I don't have the money at the moment). Once they just mentioned something about a temperature sensor...
Any ideas?
thanks...
Michael
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Hi, The first thing to do is to hook up an external monitor and see if you have video. If you do then the problem is in the cables to or the LCD itself.If not you have a problem with the logic board and I would have your serial number checked to see if your computer is covered by the recall. Assuming you have a cable or LCD problem I will include the link for repair. Choose your model and click. Good luck.
MacBook Pro 15"
这个答案有帮助吗?
得分 3
4条评论:
Well, with an external monitor it does work...if it is the logic board it would be costfully, right?
thanks anyways...
完成的
No if ti works with an external monitor the logic board should be good. Look for a loose or bad cable to the LCD first as they are cheaper and easier to replace.
完成的
thanks...I'll check it when I find time...I'll report if it will work or not...
by the way I just noticed that the graphic card in my macbook pro officially is known to cause problems and that there is an "exchange/repair" programm. Do you think I sould take advantage of this?
完成的
one more question...if it would be a bad cable or a wrong connected cable, wouldn't I expect then the screen to stay black all the time? Because when I start the computer I see the white screen with the gray apple and then it suddenly dissapears...
thanks again...
完成的
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 625
