跳转到主内容
P5 pentalobe and 1.2 pentalobe screwdriver
Hello,
I am sorry if this is not the correct category for my question but I do not know where else I can ask this.
I am looking for a P5 pentalobe screwdriver because I have to do some fixing on my MBP. In my country it seems there is not P5 pentalobe screwdriver but googling I found out that P5 pentalobe screwdriver's dimension is 1.2 mm; so my question is: is a 1.2 mm pentalobe screwdriver and a P5 pentalobe screwdriver the same?
Thanks.
-C
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
1个答案
已选择的解决方案
P sizes TS sizes PL sizes[11] Dimension Usage
P1 TS0 Unknown
P2 TS1 PL1 0.8 mm iPhone 4 (Late), 4S, 5, 5C, 5S, 6, 6 Plus, 6S, 6S Plus
P3 TS2 Unknoen
PL2 0.9 mm Apple Watch Band
P4 TS3 Unknown
PL3 1.1 mm
P5 TS4 PL4 1.2 mm MacBook Air and MacBook Pro with Retina Display
P6 TS5 PL5 1.5 mm MacBook Pro (2009) Battery - 15” only. Also known as Apple specialty tool 922-9101
PL6 1.6 mm
这个答案有帮助吗?
得分 17
1条评论:
P5 screwdriver is as the same as 1.2 .You are correct. Had the similar issues before and 1.2 worked for me .Ho fir it
完成的
添加一条评论
添加你的答案
Carlos 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 77
总计 27,842
