Samsung Galaxy Note 10.1 stuck in reboot cycle
plss fix this samsung galaxy note 10.1
Have you tried pushing the power and volume up buttons together or the power and the volume down to power down the device? If it is off you could then either try to start it normally or try to flash a new ROM onto the device.
这个答案有帮助吗?
I would take out the battery and then put the battery back in, but if it is an internal battery like an apple product you might have to get the battery to turn off fully until it will not even turn on then charge it and turn it on and hope for the best.
这个答案有帮助吗?
i try it but didnt work
You might have to reset to factory default to see if that fixes the reboot cycle.
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 430
2条评论
why i cant fix
由 Adam Matthew 完成的
it was stuck in reboot cycle plss fix
由 Adam Matthew 完成的
