跳转到主内容
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 个问题 查看全部
S4 i9515 Sim card removed error.
Hello everyone
Ok so I have been using this wonderful device for 2 years with no problems at all.
but for the past 2 months this error happens normally in different conditions ( while using, on the desk , in my pocket ,etc.) .
It gives an error that sim card removed please restart your phone.
Tried all methods in this 2 threads
Xda sim card removed s4
Android central s4 sim card removed error
Nothing really helped (applying pressure on the sim tray add a foam heat ic etc..)
I went to Samsung in Turkey asking them if they can fix it they said it's a faulty mainboard and we don't change nor fix mainboards :D.
Which left me with one option...
I have to change the mainboard myself ( any other ideas would be awesome )
The problem is.. my phone is i9515 and it's very limited here in Turkey.
I could only find the i9505 mainboard which is exactly same spec for the i9515
( I can't order one online because Turkey uses registered imeis and buying one abroad will cause my phone to get blocked by network operators)
will replacing the i9515 mainboard with a i9505 mainboard might cause a problem ?
Thanks in advance :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
最有帮助的答案
Do not replace the mainboard if you have not tried replacing this part yet:
This is the sim card and microsd card reader assembly for your phone.
http://www.ebay.com.au/itm/Original-Sams...
这个答案有帮助吗?
得分 2
2条评论:
Tried this like all other people who is having this problem with no good
lots of S4's came with faulty mainboard like mine.
Will the i9505 mainboard work on the i9515 ? :D
完成的
If you're referring to the screen frame. It will not physically fit on there as they are different. You will need to get a i9505 mainboard fitted on a i9505 screen.
完成的
添加一条评论
BEN: NO!!! I changed only SIM card and MicroSD reader and problem is continue.
Same question, exist other comaptible mainboard for i9515? (fe 9505,9506,...)
这个答案有帮助吗?
得分 0
添加一条评论
Have you figured it out? I am facing the same situation: i can not find a 9515 board, only 9505 ones...
这个答案有帮助吗?
得分 0
添加一条评论
Yes , for anyone facing the same problem
Don't change you sim tray
Dont try anything
The problem will happen again
If you are using i9500 then buy a new mainboard for i9500 ( can be found easily)
For i9505 also buy a i9505 mainboard ( can also be found easily)
I9515 just buy an i9505 mainboard it will fit perfectly you just have to flash i9505 rom on the i9505 mainvoard (obviously!)
That's what i did, i ordered an i9505 mainboard for my i9515 from ali express ,flashed i9505 rom ,i got it for 40$ and everything went perfect.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
UnluckyUser 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 5,639
