跳转到主内容
Canon's Rebel XT is one of Canon's early entry-level DSLR's with an 8 MP sensor. Also known as the EOS 350D and the EOS Kiss Digital N.
How complicated is it to replace the PASM dial using a junker?
I have a great old Rebel XT and the PASM dial has the insert missing. I have a junker camera with a perfect PASM dial. No way to just remove the PASM dial insert that I can see.
How complicated would it be just to take both cameras apart and rob the good PASM dial from the junk camera to make the good one have a legible PASM dial?
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The insert of the mode dial is glued in. If it managed to detach itself from your good camera, it should not be too hard to get it off your junker.
There's a small positioning notch opposite the green AUTO icon, with an x-acto knife and some patience it should be possible to get the insert off.
If you opt for the disassembly route, your best bet would be to swap out the complete top covers between the two cameras. You may use the disassembly guides of the Xti/400D, there's not much difference between the two.
这个答案有帮助吗?
得分 1
1条评论:
@kaykay This was the best guy on cameras the site has seen but we haven't seen him for a while
完成的
添加一条评论
添加你的答案
Van Adams 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 6
过去 30 天: 12
总计 237
