跳转到主内容
Are Torx Security bits compatible with non-security bits?
I am looking to upgrade my wife's old Macbook Pro with an SSD, following this guide: MacBook Pro 13“一体式2010硬盘更换
It says we need a T6 Torx screwdriver. I thought it was weird that the driver kits being sold by iFixIt wouldn't include anything higher than T5 for non-security Torx bits, but then I saw the following on this page: TR6 Torx Security Screwdriver
"Security drilling on this driver makes sure that you won't be stopped by anything, even though this driver still works great in non-security T6 screws as well."
So, can anyone confirm if Torx Security bits are compatible with Torx non-security bits, and does this hold true for all Torx bit sizes?
Precision fixed blade screwdriver engineered by iFixit.图片
产品
$5.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
添加一条评论
2个答案
已选择的解决方案
The difference between security torx and standard torx is the hole drilled in the center, this allows the driver to slip over the pin located on the security screws. Otherwise they are identical sizes.
这个答案有帮助吗?
得分 5
1条评论:
is just the hole the difference? both share the same sizes?
完成的
添加一条评论
最有帮助的答案
Of course they are, all it is, is an extra hole.
这个答案有帮助吗?
得分 7
添加一条评论
添加你的答案
Help Computer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 25
总计 24,933
