跳转到主内容
1.83 GHz Core Duo 处理器 或 1.83, 2, 或 2.16 GHz Core 2 Duo处理器 A1208 (EMC 2104/2110/2114/2124)
excessive noise from coolers after replacing hdd
The new HDD is installed on the imac has no temperature sensor connector and cable leave that loose. That is not connected. I closed the imac and OSX install correctly. But the problem is that the cooler makes excessive noise. Probe smcFanControl or programs like fancontrol but I had the solution. I recommend doing to fix this problem?
Best Regards!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Replace the temperature sensor. Apple part #922-7242. iFixit does not carry this part. You can get one from Welovemacs for $59.95: http://www.welovemacs.com/9227242.html
or from me for $35.00 (click on my icon and email me)
这个答案有帮助吗?
得分 4
2条评论:
完成的
完成的
添加一条评论
There is software called HDD Fan Control designed to fix this problem, it uses SMART to track the drives temperature instead of the sensor, and does control the fan correctly
www.hddfancontrol.com
Works great
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Gustavo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,445
