跳转到主内容
加入维修社区 - 创建账户
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
How do I remove dvd?
Computer won't boot and I can't remove the dvd.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
If the computer will not power up with battery or external power you will have to tear the unit down and take the drive out of the machine and then take the top off and then remove the disk. If you can get power to it, attach a usb mouse and hold down the right side button when you put power on it and if it can it will push out the disk. Also on some the of the drives there use to be a push button just inside the left or right side of the drive and with power it would activate the eject sequence. But it also requires power.
Good luck
这个答案有帮助吗?
得分 3
2条评论:
+ If the computer won't boot, what does it matter?
完成的
Here is a link to the guide to remove the optical drive. +
PowerBook G4 Aluminum 17" 1-1.67 GHz SuperDrive Replacement
完成的
添加一条评论
Use
the old double sticky tape trick.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
marla 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 884
