跳转到主内容
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
263 个问题 查看全部
White screens flash and then powers off..
So I have an Nintendo dsi XL and I replaced the power board and from that time i have the 2 screens that flash white and then power off..
I already tried to reconnect all connectors, but that didn't help...
Any ideas ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
UPDATE 2.0
It was the Fuse un the power board that caused all that trouble. In fact it was a fuse with resistance! So it powered off when it was underpowered! I just removed the fuse and it worked (replaced with a wire)!
I hope this will help somebody with the same problem!
Louis
这个答案有帮助吗?
得分 0
1条评论:
which fuse???
完成的
添加一条评论
最有帮助的答案
OK I FIGURED SOMETHING OUT !!!!!
When I push SELECT and VOLUME DOWN on boot it works BUT when I power it off on MAX brightness it doesn't power on anymore !!!! SO if I put the brightness just one step DOWN it WORKS !!
Still I would like to know what's causing that problem
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Louis de Looze 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 108
