跳转到主内容
Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
68 个问题 查看全部
Not responsive to trackwheel.
Powers On ok, but that is all it does. Cannot scroll to any menu.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Probably needs a replacement clickwheel or there is liquid damage to the unit causing it to behave erratically.
这个答案有帮助吗?
得分 1
添加一条评论
does not respond to the trackwheel.
Only showing 1 song and plays only that song.
Has not gotten wet.
这个答案有帮助吗?
得分 0
2条评论:
Have you tried to reset your iPod? Have you tried to connect it and checked with iTunes how many songs you have on there as well as the format of the songs? Have you tried to play them through iTunes? Does your click wheel allow you to make any menu changes?
完成的
I'd too say that. Furthermore, I dunno it's a related issue, but the iPod Nano recently got a recall, still active AFAIK, because of heat issues with the battery, with melting plastics as a possible end result.
Maybe I'd give that a check.
完成的
添加一条评论
添加你的答案
mcarmi2k 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 7
总计 2,808
