跳转到主内容
加入维修社区 - 创建账户
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
fingerprint doesn't work anymore I forgot backup password
My fingerprint doesn't work anymore and is asking for my backup password but I forgot it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
5条评论
If it's anything like the iphone you may have to reset your phone.. does it give you the option to change your password?
完成的
i want my backup password
完成的
I want backup password
完成的
I want my mobile finger print black up password
完成的
I can't get the password can anyone help me PLZ.??
完成的
添加一条评论
4个答案
已选择的解决方案
I forgot my fingerprint backup passworkd
Update (10/01/2022)
I cant make any pls help me this ifixit.com
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
If you forgot your Google account password you can’t use your phone after resetting it back to factory. It will say the phone was restored, enter the details of the account holder to continue.
这个答案有帮助吗?
得分 2
添加一条评论
Samsung’s fingerprint sensor does not work 100% all the time. Sometimes, even a tiny speck on the screen or on the finger can lead to misreading. After several attempts of unsuccessful logins, usually five, the device will then ask you to enter the backup password.
There are two things that you can try to regain access to your phone.
1) By forcing the phone to ask for the registered Google account. This can be done by entering the wrong password 20 times. Once the popup shows asking for the Google account, make sure that you enter the correct credentials. Keep in mind that a Google account does not have to be a Gmail account. It can be a third party email with a separate password. If you enter the correct credentials, the device will be unlocked and will ask you to enter another password.
2) If you are unlucky and also forget the Google account credentials, the only way out is by performing a factory reset. There’s no other way than this. As the name suggests, the device will be restored to its factory state, which means everything will be deleted from your device’s internal storage,
For reference, here are the steps how to do a factory reset:
  • Turn off the device.
  • Press and hold the following three buttons at the same time: Volume Up key, Home key, and Power key.
  • When the phone vibrates, release the Power key but continue to press and hold the Volume Up key and the Home key.
  • When the Android System Recovery screen appears, release the Volume Up and Home keys.
  • Press the Volume down key several times key to highlight ‘wipe data / factory reset.’
  • Press Power button to select.
  • Press the Volume down key until ‘Yes — delete all user data’ is highlighted.
  • Press Power button to select and start the master reset.
  • When the master reset is complete, ‘Reboot system now’ is highlighted.
  • Press the Power key to restart the device.
这个答案有帮助吗?
得分 1
1条评论:
@v3nuo
You are coming very close to get some repercussion from your habitual spamming. You are always linking to the same site which makes your answers spam. Be advised!
完成的
添加一条评论
I forget my backup password
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Esperanza Rodriguez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 3,877
