跳转到主内容
加入维修社区 - 创建账户
Samsung WB2200F 60x zoom dual grip camera released in 2014.
Why can't I remove the cover of the camera?
After taking out all of the screws from the body of the camera, the outer shell will not come off.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Usually the body shell has small plastic hooks inside that keep it together even when the screws are removed. Also, note that sometimes screws are hidden under stickers: make sure you remove these too.
Once the screws are all out, you need a prying tool to gently pry the shell apart along the seams without breaking the hooks.
Pay attention, the shell may have flat cables attached to it that must be carefully disconnected before the shell can be detached completely.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Rachelle 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 234
