跳转到主内容
松下 LUMIX DMC-LX100是一款发布于2014年的便携式数码相机,她带有12.8MP像素的MFT尺寸传感器,支持4K视频录制,带有WI-FI传输功能。 LUMIX DMC-LX100是松下LX系列第一款采用MFT尺寸传感器的机型。
Losing date and time when main battery removed
When I recharge my battery the camera loses the date and time. All other functions appear to work. When the date and time is reset it is correct until the battery is removed again. Can this be fixed easily?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
There is a tiny watch size battery cell on power board, top right side (view from LCD side) under top cover. Little challenge to replace as it's really small and It is welded to a two flat steel lines (not soldered). Not sure the voltage as mine is also dead and shows 0.6v and it has no any markings on it. Could be around 1.5v but can also be a 3v. But seems that there is an extra room around for a larger size cell may fit.
这个答案有帮助吗?
得分 3
2条评论:
Mike, had you replace the battery? what model of battery did you buy?
完成的
ML421
ML621 is also compatible
完成的
添加一条评论
最有帮助的答案
See if there is an additional CMOS battery that would handle that.
这个答案有帮助吗?
得分 4
1条评论:
There's no mention whatsoever of an additional CMOS battery in the user manual, so most likely if there is one it's not user replaceable...
完成的
添加一条评论
I read in another forum that the camera may only charge this "time keeper" battery while on, so leaving it on with no sleep mode and the LCD off overnight mat be enough to charge up the tiny internal battery.
这个答案有帮助吗?
得分 2
1条评论:
This seems to work for me, but would most likely need a few more months to validate (on a next vacation) :-)
完成的
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 61
总计 2,340
