跳转到主内容
加入维修社区 - 创建账户
eMac 是一款基于 G4 处理器的多合一 Mac,专为教育市场设计,于 2002 年 4 月发布。它是最后一款使用 CRT 显示器的 Mac,并以低廉的价格向学校及其他机构出售。
eMac freezing up. Why? How to fix?
I got it back in 2004. it ran well for a long time, I used it mostly for iMovie and for watching movies and listening to music. basic computer stuff.
I think it started running hot, or the fan started to make a lot of noise (I was 14 so I don't remember very well) then I think it started taking longer to boot up, and sometimes would not boot up at all (I would get a solid-color screen the precursor to the startup sequence, but nothing more). when it did, it would last somewhere between 5 minutes and an hour before simply blinking off. So I put it away for 6 years.
Now it turns on but is often unresponsive, I believe the problem is related to the OS or the hard drive being too full (I seem to recall it telling me a few times that it didn't have enough space for x or y)
I started it up in single user mode, just to see what would happen.. or if it would do it. it does, but I have no idea what any of this stuff means.
maybe I should just reinstall the software (I lost the discs so I will have to either buy or download new ones)
any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
To get this classic back up and productive again I would open it and blow out all the dirt, this will make it run cooler. Replace the PRAM battery, be ready to max the RAM out and drop in a new hard drive.
Here's how to open it up: http://www.wilko.com/emac/
You need a 3.6V Lithium, .5AA battery, about $20 at Radio Shack plus tax or from me for $12 + shipping.
RAM maxs out at 1 or 2 GB according to which machine you have, most do not require pairs. Go here and identify you machine to know what will work: http://www.ramdirect.com/macs/eMac.html
Hard drive is a IDE drive you can go up to a 128 GB without problems
You can download some free software here: http://software.informer.com/getfree-ema...
You can get system 9.2.2 software here for $29.95
http://lowendmac.com/deals/best-classic-...
Let us know if you have other questions.
这个答案有帮助吗?
得分 4
2条评论:
Good info +
由完成的 分享
link recommended above ramdirect etc.. does not work!
由完成的 分享
添加一条评论
Certain lot of eMacs defective. Try to get it to boot in target disk mode onto other working mac. You have to disable ATI Radeon.kext extensions. First two I think. It should not freeze after that - this is the solution I found to be useful.
这个答案有帮助吗?
得分 1
2条评论:
Disable ATI? Do you have a link supporting this? Or the defective eMacs?
由完成的 分享
Google - eMac freeze fix disable ATI - should get some hits
由完成的 分享
添加一条评论
If your eMac is freezing, there's a good chance that yours has the exploding capacitor syndrome. I replaced the bad ones in my own eMac in order to get it running again. It's the same exact issue that the iMac G5s (created at the same time) had. :) A quick way to find out if the caps are bad is to open the memory door on the bottom. I believe you can see a couple caps there. They should be exploded on top.
这个答案有帮助吗?
得分 1
1条评论:
If you do have to replace the caps, you should make sure that you get switching power supply rated caps. I've opened my eMac up recently and found that the Nichicon caps that I installed previously had exploded AGAIN! The eMac's still running, but it probably won't be long before it starts to freeze again.
I guess the caps weren't good enough for the crazy load they were getting. And Nichicon is a good brand too!
由完成的 分享
添加一条评论
添加你的答案
Blaise 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 29
总计 5,694
