跳转到主内容
Repair and disassembly guides for many types of D-Link routers.
15 个问题 查看全部
The internet doesnt seem to work through my DI-604 d-link router
I am trying to connect two computers to the internet through the router and its not working. I had it connected in the last place I lived in so Im not sure what the problem is. Can someone please help me with this?
Update
One of my computers has windows xp operating system. The other one is a linux operating system. I go through shaw. SB5100 surfboard cable modem. All the lights go green except the pc activity which is orange and the standby light which is not lit up.
How do I set up a PPOE or clone the computers MAC?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Please tell us what operating systems you are using. What type of internet service o you have? What modem do you have and does it have any lights on it?
完成的
Thanks you machead3. After going to the link we discovered it was a simple fix. We have internet on both computers now.
完成的
添加一条评论
1个答案
已选择的解决方案
Modem
line goes into a special port on the router usually it's a colored one. Other computers go into the other ports.
DEPENDING UPON YOUR PROVIDER you may have to set up a PPOE on the router, or clone your original computers MAC (nothing to do with Apple Computers) address.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
这个答案有帮助吗?
得分 2
2条评论:
Use this link if you don't have it. From it you can download TFM. It will have directions.
完成的
If you have directions you should go to the router setup page, and use the wizard. If not go through the routers setup pages until you find select your internet connection type (WAN) and use the online help.
完成的
添加一条评论
添加你的答案
Tabetha Gibbins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,636
