跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
MacBook Pro Booting slowly
After installing El Captain my MacBook Pro is booting up slowly.
Someone suggest turning off File Vault. Found info but not how to turn off.
Update (04/18/2016)
Sorry about late responce and thanks every one who responded. I will attempt to do what was suggested.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
First try going into your startup items and remove unneeded one:
Go under the Apple to System Preferences > Users > start up items
You may need to unlock it it using your password.
这个答案有帮助吗?
得分 3
3条评论:
going to System preference the only thing showing start up disk. clicking on it ask to pick a start up disk. No other buttons for state up items. Is there some place else to find start up items. Even my Mackeeper does not list any thing as far as start up. It has a uninstall button but no instruction on what is safe to remove .
完成的
Go under the Apple to System Preferences > Users > start up items. Not start up disk.
Second MacKeeper is a virus with a class action law suit. Get rid of it it.
http://appleinsider.com/articles/15/08/1...
完成的
Follow this Apple guide: Use FileVault to encrypt the startup disk on your Mac at the bottom of the doc explains how to turn it off. One you have disabled it made a full back up of your drive.
Then I would recommend you clean out your old cache & log files using one of the utilities from the apps store and pull anything else you can think of you don't need.
Then I would boot the system up from an external bootable drive so you could run Disk Utility to check the drive. Last thing here is to run a hard drive defrag program like Disk Genius.
This should bring back the zip you had.
完成的
添加一条评论
Reset the pram sometimes helps, upgrade to ssd best option
这个答案有帮助吗?
得分 0
1条评论:
Thanks Scott but not very technical so what is pram a where do you go to reset it. Also what is ssd and where to go to update
完成的
添加一条评论
添加你的答案
novosad 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 113
