跳转到主内容
Version 2 of Parrot's toy quadcopter with HD camera, controlled over Wifi by smartphone.
24 个问题 查看全部
How can I fix my drone after crashing into water?
My AR Drone 2 has crashed into water. I put it for a week in a tight plastic bag with some rice trying to dry it out. However, seems something went seriously wrong as when I connect the battery it didn't respond at all.
Now, first how can I tell which part has been damaged?
second: what is the best way to fix that?
Many thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Putting it in rice may have ruined it. Its food not a solution. Find someone that does micro board repair.
这个答案有帮助吗?
得分 1
添加一条评论
I have faced the same situation when my DJI drone has fallen into the water. I have tried some basics steps at my own risk.
1) Turn the power off and remove the battery.
2) Check your warranty: If your drone is still covered by the warranty, there’s little more than you can do except put it in a dry, warm and ventilated place until you can send it off to your supplier or 'best drone repair shop for DJI Drones'
3) Towel dry the rest of the device.
4) Put the device in the oven at the lowest possible temperature, 125F to 175F, for several hours. This will dry any remaining moisture in the device. Do this as soon as possible. These temperatures are above the 104F that DJI recommends.
这个答案有帮助吗?
得分 1
1条评论:
How can you solve your problem put it in the oven? I should read about how to repair things with liquid damage. Drying the water is as bad as putting it in rice. Inform yourself before giving this type of answers, is misinformed and is misinforming people who may not have much idea that is effective or that will damage your device.
If something is wet and you want to repair it, read this please: Electronics Water Damage
完成的
添加一条评论
try to give the motherboard a 100% isopropyl alcohol bath!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amgad 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 8
总计 1,062
