跳转到主内容
關於自行維修iPhone所需的任何一切,從最新的iPhone15產品線,一路追溯到2007年所發布的初代iPhone。iFixit有著每一台iPhone維修指南、拆解資訊,並且完全免費,還有全宇宙最好的更換配件、工具、技巧!
36472 个问题 查看全部
问题已关闭
Touch screen not working
Hi after having an iphone 3g for about 2 years i noticed that areas of the touchscreen were becoming unresponsive. This wasn't much of a problem until earlier today when the touch area where the unlock slider is located stopped working. Now i can't unlock my iphone so it is pretty much unusable. Other then the touch screen becoming unresponsive there are no scratches/dents/breaks in the glass of the iphone screen I am wondering how do i fix this? and what parts would i use?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Also have same problem, dropped my iPhone 5s and now my touch screen is unresponsive and I can't unlock the phone. My contacts are located on the phone and I would like to get them off before I attempt a factory reset (not sure whether this will fix the screen problem). 3rd party tools like iPhone Rescue and iTunes still require the user to manually trust the connection on the phone which is not possible due to the unresponsive screen. All I'm concerned about are my contacts and I would appreciate any advice on how I can retrieve my contacts from the iPhone.
完成的
添加一条评论
1个答案
已选择的解决方案
just follow this guide iPhone 3G Front Panel Assembly Replacement
you'll need this part iPhone 3G Front Panel
iPhone 3G Front Panel图片
产品
$9.99
这个答案有帮助吗?
得分 0
2条评论:
Hi pollytintop thanks so much :D but just to be 100% sure if i replace the iphone 3g front panel my touch screen will stop being unresponsive?
完成的
unfortunately nothing's 100% sure. you could try a restore on your phone first and then if that doesn't work try digitizer replacement.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 4,407
