跳转到主内容
Will not boot to CD, HDD, or boot options
I have a friend who gave me his iBook G4 to fix. Thinking I could fix this with no problem, since I had fixed MANY other Macs before and since I have extensive computer repair experience I said I would do it.
This computer has had no end of problems. At first, I determined I could not boot to a CD effectively since none of my normal diagnostic CDs designed for PowerPC were booting. I attempted formatting the drive and then loading a version of Mac OS X Tiger, and that almost worked. I say almost worked because midway through the install, the computer shut itself off for no reason. I diagnosed the hard drive and found it to be a good hard drive (using many tools over the course of this). I sold him on buying a new CD drive. Did that, and the computer still would not boot to a CD.
It should be noted that at this point the computer progressively got worse at attempting to boot any CDs. I formatted the drive multiple times with an Apple Partition Map, sometimes I even blanked out the drive with all 0s just to see if it would boot. Sometimes it would, and sometimes it wouldn't. After blanking the drive, I was able to get TechTool Pro to run, but only for a limited time before the computer froze. I determined it must be the logic board, so I ordered a new one. After a couple of misplaced orders and shipping snafus, I finally got my hands on a logic board that supposedly was used, had been tested, and was 100% working. It came with the frame and everything, so I simply unplugged the LCD and other parts from the logic board that I thought wasn't working, and plugged everything back in to the new one. The computer turned on and allowed me to see boot options.
However, now I could not get any of the boot options to actually boot. The CD drive reads the CDs fine in the boot options menu. So I decided it must be the hard drive cable. So I ordered and replaced that too.
Basically, I have now replaced the CD drive, the logic board/frame/heatsink, and now the HDD cable. After I installed the new HDD cable there was no change. I thought there MUST be something else wrong, but I had no idea what.
As what I thought would be a last ditch effort, I reformatted the hard drive again with 2 partitions, one on the back end of the drive to hold the Tiger OS X DVD installer. After I imaged that over using Disk Utility on another working Mac, I put the HDD back in. It sees the HDD image, so I try to boot from it. No dice.
At this point, any attempts to boot resulted in a blank blue screen, or the apple logo with rotating wait symbol underneath (that would occasionally freeze, but sometimes it would just keep going). Each time I attempted a boot I waited at least 10 minutes before deciding nothing would happen.
So I tried the following:
-Reset the NVRAM via Open Firmware (Command Option O F, reset-nvram, reset-all). Did that, no change.
-Reset PRAM (Command Option P R). Waited for second chime, then restarted again and pressed and held Option to get the boot menu. Now NOTHING happens.
-Try to load Open Firmware again. Now will not accept keyboard input.
-Try to reset PRAM again. Still no ability to access Open Firmware keyboard input.
-Try reset PMU per Apple instructions, now every time I turn it on, I get either a blank screen or a discolored one, regardless of whether I press Alt. Sometimes Red, sometimes Green, Sometimes just a horizontal line of white at the top with the rest black.
So now what do I do? The old logic board is taken apart now and is unlikely to be used again, and I can't imagine my tinkering around is irreversible with simple NVRAM and PRAM and PMU settings. There has to be SOME way to figure this out. I throw myself on the mercy of the experts.
UPDATE: After leaving it off for a while, it seems to be able to get to the boot option screen again, but still won't boot any of the options.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Well, I was finally able to get it to boot into Apple Hardware Test off of some iBook G4 CDs I managed to procure (these were not from the owner, who has lost his set). It said the logic board passed, but when testing Mass Storage, the test froze. I attempted a removal of the hard drive and while booting the options menu, it freezes after loading the 2 possible options from the CD. I am wondering if that indicates anything in particular? I am running hard drive tests on another computer now with the iBook's HDD in an external USB enclosure.
完成的
Tested the hard drive using 3 different tests, all of them passed. Ran Apple Hardware Test again. Let it load while I checked on something in the kitchen. When I got back about 10 minutes later, it was frozen. I hadn't even started the test yet. Maybe it's not the mass storage after all, but what would explain the logic board passing but it still freezing?
完成的
添加一条评论
1个答案
已选择的解决方案
Sounds like it has been hit with ESD ;-) I would replace the RAM.
这个答案有帮助吗?
得分 3
4条评论:
完成的
Well, I took the RAM that was in it out as a test during several stages, and there seems to be no difference. 256 MB is built into the logic board.
完成的
If it locked up while booted from the CD, I would first replace the RAM. I would then reformat the drive and use the "write zeros" option. Then reinstall the system.
完成的
I've written zeroes to the hard drive many times, but have not successfully been able to do that from the iBook itself as it will not boot into the Mac OS X installer. It will however, for a brief time, boot and run Apple Hardware Test. The RAM is absent from the machine, with 256 MB built in to the logic board.
完成的
添加一条评论
添加你的答案
Adam 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 6,733
