跳转到主内容
The Garmin Nuvi 1490T is an ultra thin, lane-assisting, Bluetooth GPS navigator that was announced in 2009.
Why is my GPS not responding to my voice commands?
When i say a command my GPS is unresponsive, no matter how loud I command it to do something I still get the same results. What should i do to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
The microphone is no longer attached to the motherboard and that is most likely the problem. Follow the provided link for more help!
Garmin Nuvi 1490T Troubleshooting
这个答案有帮助吗?
得分 1
2条评论:
I had that problem also and it drove me nuts but I figured it out and it was so simple it was stupid. After I updated the maps and made sure regions and language matched and everything set to english. Now do this.on your post screen hit the APPs button scroll down to voice command. Now hit the little tool icon at the top left and uncheck Voice Command wait a few seconds then CHECK voice Command turning it back on. then it started working again.
完成的
my nuvi dosnt even have a voice command app so now what?cant even get off the ground with my new nuvi 68
完成的
添加一条评论
There are so many reasons that GPS not responding to my voice commands?
Below are some of them:
  1. You haven’t download the latest version.
  2. Is your voice and text language the same?
  3. There can be microphone issues.
To solve this Voice Command Not Working in GPS, you can perform a hard reset of your device, make sure you store all the backup of your device.
If problem not solved then feel free to contact Service Center.
这个答案有帮助吗?
得分 0
添加一条评论
Some popular Gps devices like- Magellan devices like magellan maestro 3200,magellan roadmate 1440,magellan maestro 4040, magellan roadmate 5235t-lm,magellan roadmate 1700,magellan roadmate 1470, and other old and newer models. We’ll help you to get easy maps, software / Firmware updates.
Are you planning a trip or going out and wondering if you could have the latest maps to make your trip or your work. Well, you’re a step away from the latest map updates. Latest map updates make sure that you always reach your destination on time with full-proof accuracy. Magellan roadmate Updates
这个答案有帮助吗?
得分 0
添加一条评论
where is 3430 Thedodsia ave
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ricardo Solis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 8,878
