跳转到主内容
加入维修社区 - 创建账户
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
phone won't turn or charge
the phone won't turn or and i can't charge the battery when it is in the phone. i've tried all the usual things, different battery, try to go into sage mode, plug into computer. it wont turn on and it wont charge the battery. worked with samsung over phone they couldnt fix it. had local guy check it out. he replaced a long thin unit part on the left side of the motherboard and hooked up some diagnostic tool to the right side of it, he couldn't get a response out of it. do you think it can be fixed ? i have pictures, contacts, etc i need to get off it. please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
It sounds to me like maybe your charging port could be bad. You said you tried using different batteries, but were those batteries already charged? If they were charged then its possible you just have motherboard damage. Which can be caused by multiple things. Being dropped or being exposed to water.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for the reply Mo. A repairman told me I need a new IC chip on the motherboard and it is due to water damage. He said it's a model PM8917 but he doesn't do it. It's a very difficult micro soldering job. Still looking for someone that can do it. Anybody know someone that can do this ? I think Samsung could but they wipe everything off it before they work on it per their policty and I want to savew the pictures, contacts, etc. on it.
完成的
添加一条评论
添加你的答案
dennis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 125
