跳转到主内容
The Syma S107 is a mini RC helicopter that uses gyro technology for stabilization. This helicopter is electrically powered and designed for indoor flight.
Why my helicopter is stoping in middle while flying?
my helicpter is flying when my remote is divereged to reciver but it is stop flying in middle when it is turned ohther side i trhink it is becoz my reciver is nt wworking properly
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Could be a number of issues:
1. Low battery power in the transmitter.
2. Receiver has a loose connection and needs to be re-soldered.
3. Other transmitters in your house interfering with the signal.
完成的
I have this type of helicopter or similar model.
Before flight, of course we check all batteries are fully charged. The helicopter may stopped as soon as there is vibration on the ground or while mid flight.
What I found out recently, there is this small cylindrical component (capacitor or crystal) of the circuit board with a loose/dry solder. This could be the cause of the glitch which you encountered. My heli is now grounded because this component has broken wires due to regular physical interference to correct the glitch. Not sure whether this component has spares or not.
完成的
添加一条评论
2个答案
最有帮助的答案
Make sure that you use the helicopter indoors. I have one, and it won't work outdoors for too long. Try recharging the batteries too. You also need to stay within a certain range or else it will be come unresponsive and crash.
这个答案有帮助吗?
得分 1
添加一条评论
Don't know if this will work on a model but in Viet Nam when the engine conked out you did an "autorotation" to set her down easy. Helicopters are designed specifically to allow pilots to have a reasonable chance of landing them safely in the case where the engine stops working during flight, often with no damage at all. They accomplish this via autorotation of the main rotor blades.
https://www.youtube.com/watch?v=ReSCUkF-...
Here's a training video on how to do it in several different choppers:
https://www.youtube.com/watch?v=qst9gODz...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
raminenirevathi 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 11
总计 989
