跳转到主内容
Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
164 个问题 查看全部
问题已关闭
Burned out ethernet port
iMac 9-1 Early 2009 2.66 Ghz
Lightning ran in on my machine through the cable modem...am now using USB to ethernet adapter from Apple and all works well.....just wonder how much it would cost to get a new Logic Board for the ethernet if available?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I think I picked the right machine icon.
Here are the A1225 machines that the logic boards should work from:
http://www.everymac.com/ultimate-mac-loo...
You know the old adage "if it ain't broke, don't fix it,"
It's working, so I wouldn't risk a major overhaul just to gain one USB port. Machines hit by lightning can have component weakening. Personally I have a 2009 MacPro that was hit and I put PCI USB & PCI ethernet cards in it to get it running. It is still running.
I would have an external backup hard drive and keep Time Machine backups.
这个答案有帮助吗?
得分 2
添加一条评论
In this situation you have to replace Ethernet port.
这个答案有帮助吗?
得分 0
3条评论:
Sadly, the Ethernet port is part of the logic board so it's not replaceable. But, one could use a USB Ethernet adapter if you can find one that is supported under OS-X which the OP did.
完成的
@danj - Dan, that's what he's using now.
完成的
@mayer - Yep! "Which the OP did"
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 671
