跳转到主内容
Logic Board Upgrade for newer
Apple MacBook Pro "Core 2 Duo" 2.4 15" (08) Specs
: Early 2008 - MB133LL/A - MacBookPro4,1 - A1260 - .
I have a Macbook pro late 2008 model with a 2.4 ghz processor logic board, I'm thinking in getting a better logic board in that same year (so that all the ports match my current chassis).
Is it possible to replace my current logic board and place a faster one into my current Macbook pro (same ports - logic board layout)?
Do you think there'll be problems with the other equipment as in speakers, super drive, keyboard, display to not work because they aren't "compatible" with the mother board I'm going to replace?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Samtaylor I would think it is safe to assume that a board from the same year will fit. I did not get into this business until lately and have no record of 2008 models, but common sense says you're right and same year should fit.
完成的
添加一条评论
1个答案
已选择的解决方案
I believe I have gotten you to the correct machine.
Stay within the same A1260 model number and you should be OK. You can upgrade to the 2.6 GHz board to make it this machine: Apple MacBook Pro "Core 2 Duo" 2.6 15" (08) Specs
Identifiers: Early 2008 - BTO/CTO - MacBookPro4,1 - A1260 - 2198
Get Apple part #661-4689
Here's how to do it:
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Logic Board Replacement
However I don't think find the small speed bump worth the cost. A better solution would be to install a 500GB hybrid hard drive. Bump the RAM up.
Standard RAM: 2 GB Maximum RAM: 6 GB*
Details: 2 GB installed as two 1 GB modules. No slots free.
*Apple officially supports a maximum of 4 GB of RAM but third-parties have been able to upgrade the system to 6 GB of RAM using one 2 GB and one 4 GB memory module.
  • [关联产品丢失或禁用: IF107-098-3]
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
samtaylor736 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 1,222
