跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。型号为A1532, A1456
Sim card tray stuck
A while ago, I removed the sim card form my Iphone. Today I decided to reset it. When I did, it said I must put a sim card in the device. But when I did, it didnt show up. So, I tried to eject it. I can get the tray to pp put, but not all the way out. I do not want to take the back off my phone.
Update (03/19/2016)
I could not manage to force it out, and do not have the tools to open the back.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I have found the following to work. Cut 2 strips of thin plastic, about half the thickness of a credit card, 1/8th inch wide and 2 inches long. With screen face down and the sim carrier partially jammed open about an 1/8th inch push the first strip of plastic in as far as it will go and then move it to one side. Do the same with the other strip but move it to the other side. This should allow you pull out the sim carrier while preventing the sim jacked sim catching.
完成的
添加一条评论
1个答案
已选择的解决方案
What are you using? You can push in the with the SIM tool, a needle, a paper clip.
If it is staying stuck, you can grab it with tweezers or fine pliers and pull it out. But beware that may be the SIM ejector is broken or the SIM is jacked up and stuck, and not letting the SIM tray slide out. In which case it is better to lift the screen and work it from inside.
Here's a guide that shows how to access the SIM reader from the inside.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
James Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 5,447
