跳转到主内容
Released in conjunction with the iPad 2, the Smart Cover is a screen protector that doubles as a stand. The Smart Cover works with both the second and third generation iPad.
Ipad cover coming apart
The cover is coming apart where it flips over at the magnetic base. There is the hard edge that clings to the iPad and a flexible, rubber cover that seemed to be glued to it. Whatever was holding it together has worn away. I tried double-faced tape to reattach it, but it doesn't hold. Any suggestions on an adhesive to use to repair it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
3个答案
已选择的解决方案
About 1/3 of my cover hinge came detached off my cover. I applied a line of superglue (Gorilla brand, but most should work), and my cover is like new (well, except for some exterior scuffs).
这个答案有帮助吗?
得分 6
5条评论:
Glad to read this works, thanks! I was tempted to do it on mine but have not dared yet to attempt it.
Did you have any trouble with making sure the detached part was properly stretched to its original position? Mine has gone off entirely and I am worried about glueing it back too loose.
完成的
Mine was only partially detached, so I had a clear guide for alignment. However, even if fully detached, the magnets should align both the main cover and the spline in the right place while gluing.
完成的
I used 4 rubber bands to align the cover with the screen, popped the magnet bar in place and it lined up very nicely.
完成的
I repaired mine with Loctite Vinyl, Fabric & Plastic Flexible Adhesive. It appears to be the same type of adhesive that apple used when manufacturing the cover. I used binder clips to hold the pieces together while the adhesive cured. Amazon, Home Depot & Meijers carry the adhesive.
完成的
@Mike Post did you replace the flexible strip between the cover and the magnetic strip, and if so, with what please?
It seems flimsy so I worry it will eventually tear if I reuse it.
完成的
添加一条评论
Just get a new one..
这个答案有帮助吗?
得分 1
7条评论:
Well, the point of iFixit is to fix things, not buy new ones. ;)
完成的
Ifixit don't usually do accessories repairs, they are pointless.
完成的
Anybody can just "get a new one". It's so easy you don't even have to type those words. The point of this forum is to FIX IT. Not buy a new one, anybody can buy a new one. But it's so friggin wasteful
完成的
Who told you fixing one-piece accessories was a good idea?
完成的
Well it's expensive, so why get a new one when there's a cheap, even temporary fix. Hence the name iFixit!
完成的
显示更多的2条评论
添加一条评论
Fevibond does the job. You can use fevibond with the fabric glue used for clothes as well. Just tried yesterday and it worked.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ron Shapiro 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 34
过去 30 天: 92
总计 26,127
