The driver's side relay usually goes first,it should be inside the door panel, new is likely expensive, go to an auto recycling yard and ask for one, it's used but cheaper,you'll recognize it inside the panel after you have it in your hand, should be the problem..
2条评论
Is it electric or manuel?
由 mayer 完成的
Is it the front or rear window? If it's the rear (and electric) window, have you made sure you didn't accidentally click the "child lock" switch?
由 Miroslav Djuric 完成的
