跳转到主内容
加入维修社区 - 创建账户
2.3L 4cyl or 3.0L V6, 6th Generation
Why can't I roll down the window on the driver's side?
2002 Honda Accord
I can't roll down my window on the driver's side. What can cause this to happen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Is it electric or manuel?
完成的
Is it the front or rear window? If it's the rear (and electric) window, have you made sure you didn't accidentally click the "child lock" switch?
完成的
添加一条评论
1个答案
已选择的解决方案
The driver's side relay usually goes first,it should be inside the door panel, new is likely expensive, go to an auto recycling yard and ask for one, it's used but cheaper,you'll recognize it inside the panel after you have it in your hand, should be the problem..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 2,294
