跳转到主内容
加入维修社区 - 创建账户
Macintosh Powerbook 140 是苹果公司早期的笔记本电脑。它配备了大型电源线、电池、轨迹球(而非触控板),是苹果公司最早使用内置软盘驱动器的电脑之一,并且键盘高度可调。它也是首款将键盘放置在机身靠后位置的笔记本电脑。
Help! My screen won't work!
I recently got an old Macintosh Powerbook 140. I have plugged it in, and when I power it on, I hear the startup sound, and the speakers emit a tone, but the screen displays nothing. I have checked for any visible damage, and there appears to be none. It may be of note that the computer hasn't been used at all for the past 20 years. I do know that the last report of its use was that the screen was a bit touchy. 20 years ago, the screen could only be seen from the correct angle, but now there is nothing. Can anyone help?
I should also note that I have little experience with physical electronics. I work well with technical stuff, but I only have a basic understanding of electronic terms. If you could explain and terms for me, that would be great. I can do some work with electronic components, but I don't trust myself with big overhaul or too much soldering. If you have any solutions that require little or no of said things, that would be great.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
Also, if anyone knows a lot about the powerbook 140, pleas add your info in a guide on the Powerbook 140 guide page. Thanks!
由完成的 分享
添加一条评论
2个答案
hello
very common failure in these machines : LCD caps and inverter caps are gone , must recap lcd screen and inverter with new capacitors , i solved this problem with all my powerbooks 140-145b-160
see this video :https://www.youtube.com/watch?v=XP-fWaDb...
这个答案有帮助吗?
得分 0
添加一条评论
If you’re still looking all these years later this may be the answer you’re looking for…
https://youtu.be/JrnzKs67YXE
这个答案有帮助吗?
得分 0
1条评论:
I actually still am. Hard to believe I first asked so many years ago! This has very much been on a backburner since about then. Caps might be the problem, but the hard drive seems to have some sort of corruption. It's a [presumably] older black drive with the rounded edges. I've tried the unit with a newer, sliver, sharped-cornered hard drive, and it seemed to work. I really wanted the original drive, but I've found no way to move data over thus far.
All that being said, this has been on a backburner for a couple years so the details I can remember are sparse.
由完成的 分享
添加一条评论
添加你的答案
Jack 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 25
总计 1,041
