跳转到主内容
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Timer won't shut dryer off
My dryer will dry clothes fine and heats up correctly after setting it up on a cycle. However, the drum keeps turning after the cycle is complete. It shuts off when I open the door but comes back on when I close it. I have to keep door open to not waste energy. What can I do to fix this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Hi,
There was an answer for this problem on iFixit back in 2016 by @mayer.
It’s for an earlier model but could be the same reasons.
Why won't my dryer turn off
It gives possible causes of the problem you described.
Hope this helps
这个答案有帮助吗?
得分 0
2条评论:
The original answer posted covered lots of options but not the cure for mine. I have posted a comment on that thread with the solution that works for me (replacing the timer unit).
完成的
I searched @mayer's page for dryer and drum; not found. So even though Helpful Harry says that there was an answer, I haven't seen it. Meanwhile I've found some possible solutions from other sites, and they are leading me to a control board replacement. For example... https://www.youtube.com/watch?v=V0_Ty4Cc...
Thank you.
完成的
添加一条评论
添加你的答案
Oscar Gutierrez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 204
