跳转到主内容
加入维修社区 - 创建账户
2012 年 11 月发布的 Lenovo G 系列日常笔记本电脑。
My machine won't regulate processor thermal heat
Hi i'm Leslie,
Ive got a lenovo g580, i3 with 8GB RAM running on Windows 10 (v1511) ,
my main problem is the Processor Thermal.
I tested my machine with the Intel Processor Diagnostic Tool 64bit latest version, managed to pass everything else but failed with the following error :
Entering run forever
1 degrees C below maximum
Test Result - FAIL
Expected Greater than 1 degrees below max
Received 1 degrees below max
Test FAILED
Please check your Processor Thermal Solution
Kindly help us with a solution for the problem because its been making my machine shut down unsuspectedly without notifying. This has caused instability when i'm working throughout the day.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Is the CPU fan running? Are the vents clear and unobstructed? Use Task Manager to see what % the CPU is running at. If high % and you are not doing much on the laptop, check what applications or processes are using the CPU the most and why
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Leslie 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 16
总计 543
