跳转到主内容
加入维修社区 - 创建账户
The third iteration of the 10.1 inch Galaxy Tab tablet.
Tablet has a pink screen, how can I fix this problem?
Tablet has a pink bach ground screen, I have already reset to factory settings and it didn't fix the problem. What can I do to fix this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
2条评论
What can I do to fix my color screen tab
完成的
Had this in the back of my head, visited a friend and her Galaxy Tab was pink. Had a think and Tadaa, opened it up as directed, removed, cleaned, replaced flat cable, all fixed. Cheers
完成的
添加一条评论
4个答案
已选择的解决方案
This is generally a failing display or digitizer, Replace it.
Here's how to do it: https://www.youtube.com/watch?v=7N9--kUh...
这个答案有帮助吗?
得分 5
添加一条评论
Sometimes the graphics cable gets dislodged
Prise open the back
Black flat cable to the right
Check line on the cable lines up with board line
A wiggle and a push helps the cable in
Put some tape across connector to prevent further dislodgement
Hope this helps
Paul
这个答案有帮助吗?
得分 3
2条评论:
Will this break my tablet
完成的
Can my tablet be fix some other way I don't want to brake my tablet
完成的
添加一条评论
My whole screen is pink and that only thing I see on my tablet what causes this
这个答案有帮助吗?
得分 1
5条评论:
Tablet has been dropped or not correctly reassembled after battery install
完成的
Could it be that it was expose to sun to long
完成的
Possible in hot climate while tablet is runing causing failing display or digitizer, Replace it.
完成的
Thanks Paul, you were spot on.
完成的
No I didn't drop it
完成的
添加一条评论
I removed the connector, cleaned it off , and put it on again. And now are all the colors there again!
Thank's a lot!
Best regards Erland
这个答案有帮助吗?
得分 0
3条评论:
Worked for me. Try it again.
完成的
I did everything you say do but it's not working
完成的
I cant do that my parents say I caused the pink screen when I was only watching something in blue screen. Filter and for some random reason the screen turned pink
完成的
添加一条评论
添加你的答案
barryh 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 105
总计 22,907
