跳转到主内容
Lenovo business laptop introduced in April 2011.
Why does my fan make a high pitched noise?
My computer is making a high pitched noise when running and when in sleep mode. How do I fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
The high pitched noise may be due to your fans needing to be cleaned, try blowing air forwards and backwards through the fan. Another option is to shut your computer off and let it cool down. If noise continues you may need to take the computer apart to do more cleaning of the fans.
这个答案有帮助吗?
得分 4
1条评论:
I had the same problem. I used a hairdryer (cold air!!!) up and down the fan outlet for about a minute, while the laptop was still one, but resting vertically on its side, and it removed the problem completely. I have seen this problem before on another laptop and cured it the same way. Don't use a hot fan!
完成的
添加一条评论
最有帮助的答案
You can start by cleaning the fan first by blowing air through it forward and backward . If this doesnt help then take the laptop apart and do a more through cleaning of the fan put a touch or lithium grease in the bearing . If this doesn't help you will need to replace the fan
这个答案有帮助吗?
得分 6
添加一条评论
Make sure of exactly where the noise is coming from before you spend any money. It could also be the hard drive. See this video: https://support.lenovo.com/us/en/videos/...
这个答案有帮助吗?
得分 6
添加一条评论
In my case it helped to carefully remove 3/4 of the round tape that sticks to the back of the fan. It holds a little brass cap that covers the fans center bearing.
I put a tiny drop of sewing machine oil on the bearing and re attached the tape with the cap. Fan works perfectly again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Emily Heffernan 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 73
总计 28,286
