跳转到主内容
加入维修社区 - 创建账户
Alcatel One Touch Idol 3 配备 5.5 英寸、1080 x 1920 分辨率显示屏,搭载 1.5 GHz 处理器。于 2015 年 6 月发布。型号为 6045Y、6045K、6045O、6045I。
My Powerbutton don't work anymore?!
My Phone was always covered by a Flipcase, yesterday i took it out cause the Powerbutton did not react.
But now it dont work anymore. At first it worked after 10 times pushing, but now i have to wait for any message, that the display come out oft "sleep" mode...
what can i do ?? i dont know if i can fix it alone :(
i dont want to loose this phone, its really New... Please help me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
the power button on the idol 3 can be finicky as they are prone to failing. they ARE soldered to the circuit board so I would advise finding a local electronics repair shop or good friend with minimal soldering experience- seeing as the actual replacement is as simple a solder job as one could imagine . the component replacement, itself, is about $8.00 online.
http://www.ebay.com/itm/Alcatel-One-Touc...
这个答案有帮助吗?
得分 0
添加一条评论
I was having the same issue for almost a week now. My phone is visibly in great condition (screen in tack, no cracks or scratches, etc.), but the power button just gave out on me. The only time I was able to use it was if I plugged it into the battery.
Finally, i decided to download an app by searching "Power Button to Volume Button," and voilà it works. I now use my up or down volume to turn my phone on! I hope this helps you, too.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christine 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 25
总计 1,484
