跳转到主内容
加入维修社区 - 创建账户
Koosh Vortex Tornado 是一款弹簧驱动玩具枪,可以发射 Koosh Spinfire 圆环。
Why does the barrel shield move freely on the gun?
The barrel shield that you pull back to insert the firing rings is not stable. It slides back and forth on the gun and does not hold its position. How can I fix this so the piece holds its position and returns to covering the barrel once I insert the ring?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The return spring has most likely been disconnected from its original mounting spot. This prevents the shield from returning to its original position.
To fix this issue, you must open up the gun and find the faulty spring. Reattach the spring to its original position and the shield should start working properly.
See our troubleshooting page liked below for more information:
Koosh Vortex Tornado Troubleshooting
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jordon Roseman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 16
总计 301
