跳转到主内容
The Verizon Ellipsis Jetpack MHS800L is a 4G LTE mobile WiFi hot-spot designed to be pocket sized and portable.
Why won't my device's battery charge when it is plugged in?
My device is plugged into a wall outlet via the charger. The charging cable doesn't appear to be damaged and everything else looks fine visually.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Mr Betts,
I would assume that the internal battery is damaged or old, and wont hold a charge. If the battery is in state of needing replaced then your device may not even turn on.
这个答案有帮助吗?
得分 0
1条评论:
My battery is new & I noticed this morning when plugging in to wall socket....it actually notified it will not charge while turned on. I am currently waiting for replacement unit because of recall.
完成的
添加一条评论
i have just replaced my tablet with a new battery and it is only charging 5%. what is wrong?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
William Betts 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,251
