跳转到主内容
This Power Mac G4 has Mirrored Drive Doors.
80 个问题 查看全部
Original Mac OS X Disc will not reinstall.
My Power Mac G4 started to run slow and slower, gave time and date messages to check it it would run . I put new battery in and two weeks later came up again. I decided to reinstall my original OS X Disc got about half way through the install and quit said it failed message, I tried it again same thing failed. Can you help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Michael, please check the date on the battery first. It may have new but old stock. Were the date and time holding? Will it start in safe mode (hold down the Shift key on start up). This does sound like failed hard drive.
这个答案有帮助吗?
得分 2
4条评论:
I tried the to in safe mode it opened in Mac OS 9.2??, but will not eject to accept a disc.
完成的
Hold down option key when starting to select the system you want. The date is stamped on the battery. Hold down mouse button on start up (to eject it), or it will boot from the CD/DVD (which is probably what has happened and your hard drive may have failed already.
完成的
Thank you for your answers. I believe I'll replace the Hard Drive, can you recommend a website to purchase part.
完成的
OWC will carry those older drives. Here's a link to those drives: http://eshop.macsales.com/search/3.5+Int...
完成的
添加一条评论
添加你的答案
Michael Farnsley 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 9
总计 209
