跳转到主内容
A tablet released in September of 2015 by Amazon featuring a 7 inch multi-touch screen display. Model Number: SV98LN
Why can't I connect my device to a wireless network?
I can't connect my device to a wireless network.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
  • If you are having issues connecting your device to a wireless network, your device may have been operating continuously for too long, and you will have to restart the device. Restart the device by holding down the power button and selecting to turn off. If you do not see the option to turn your device off on your screen, hold down the power button on your tablet for 40 seconds until it turns off, then start it up again.
  • If rebooting the device doesn't solve your problem, your tablet may be running outdated system software. Instructions on how to update your device software can be found here.
  • If you are still having issues, your WiFi connection may be the problem. When attempting to fix your WiFi network you should take these several steps (no particular order is required) :
  1. Power cycling your wireless router. Instructions can be found here.
  2. Changing the type of security on your router from WEP to WPA2.
  3. Changing the setting on your router to disable 802.11n and limit it to 802.11g.
  4. Finally, Changing the settings on your fire tablet to limit its wireless speed to 54Mb/second.
  • Additional help on this issue can be found here.
  • For more information regarding troubleshooting your Amazon Fire 5th Generation, click here.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hootan Adibfar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 560
