跳转到主内容
The OontZ Angle 3 is a high quality, lightweight speaker made by Cambridge SoundWorks.
Why does the sound come out weird?
Whenever I try to play music the sound comes out muffled and funny. I’m unsure exactly what is wrong. What can I do to resolve this issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
The most likely cause of this problem is probably due to the speakers either being dusty or
broken, or a poor connection between the phone and the speaker. First and foremost just check and see if the device has a good connection by keeping the phone nearby and clearing obstructions between the two. If that works then the issue should be all set.
If it is the speakers themselves causing the issue, first try to play music through the speakers and see if one is broken. If there isn’t a broken speaker then it may just be a dirt buildup on the surface of the speaker. If there is a broken speaker then the speaker will have to be replaced.
If there are further issues with the sound quality I suggest checking the troubleshooting page for the speaker in order to find the cause of the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mason Hollander 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 30
总计 3,031
