跳转到主内容
The OontZ Angle 3 is a high quality, lightweight speaker made by Cambridge SoundWorks.
Why won’t the speaker turn on?
When I try to play music on the speaker, the speaker won’t turn on. It seems to be unresponsive to the power button being pressed. How can this be fixed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
10条评论
I have he same problem used it once tried to turn it off so I could leave the house and it would not turn off....Came home tried to use it again will not turn on been charging all night and it acts like it will not charge the charging light stays red tried to turn it on while plugged in to charge and still nothing it has never been near water so any kind of help would be great
完成的
Hello, my speaker Oontz angle 3 I bought it again, the first day it worked very well and I only used it for a while, on the second day I did not want to turn it on and it did not charge because neither a light went on, so the next day I thought about repairing it but trying to turn it on it worked again and then I turned it off after a few hours I returned to turn it on and once again I did not want to light it and it did not load either, it did not turn on a light. I do not know what can happen to you and I need help.
完成的
Mine doesn't work neither, I already returned one to Amazon and I am about to return the replacement one they sent me.
完成的
You should return it . same problem here
brand new used once, never turned on after, jist the lights. Guys.DONT BUY EDISON.its crap.
完成的
i have an blackmore speaker and it works fine but the sound wont come out.i didn't do anything to it
完成的
显示更多的5条评论
添加一条评论
4个答案
已选择的解决方案
When the speaker does not turn on, it could be because of a few reasons. The first reason is that the battery is not charged. Charge the battery for a few hours and then try to turn it back on. The second reason is that the Oontz Angle 3 may have been water damaged. The Oontz Angle 3 is not waterproof, so place it a designated area and give it time to dry out. So if neither of these solutions work please refer to the troubleshooting page to identify the real cause of the issue.
这个答案有帮助吗?
得分 6
4条评论:
If it’s frozen and it won’t turn on or off, let the battery die all the way (this could take a day or two). Let it charge for about 30 seconds. Turn it on and connect your Bluetooth.
完成的
but why it’s greatest Speaker ever though to work
完成的
How do I fix the on on the speaker
完成的
How do I fix the ion explorer on/off because does not work
完成的
添加一条评论
最有帮助的答案
it happened the same to me, in my case the problem was the power switch, i had to gently press it downwards while i was moving it to "ON", that worked for, such a pitty that i had to figure it out because i paid for it... but at least it works.
The thing is that if i press it a little bit upwards it will turn OFF, so it is a "contact" problem, you need to press it downwards while you turn it on so it stays well placed in order to make the right contact and turn this on.
Hope that helped.
这个答案有帮助吗?
得分 7
6条评论:
Thank you for posting! This solved my problem. :)
I had to oeel back the neoprene sleeve to slide it as you suggested, but that worked like a charm!
- mkk
完成的
Thank you so much but I just opened this %#*@ thing. I expect a device that I pay $60 for to work properly. This is sad. I've reviewed hundreds of mods, tanks, and kits. I was so disappointed in this product. Wismec is not good with customer support whatsoever! I am considering still doing the review but I have a feeling they will never send me any more products to review if I do that! In the end I have to be honest to the people watching the review. Two companies now won't be sending me products. Voopoo and wismec! If I have to continue buying these products which is more than fair, however so is my honest opinion of their products so I guess it is what it is! Sorry for the rant, thanks again for communicating the explanation and the solution!
完成的
Wow! That immediately worked for me! Thank you!
完成的
I'm lost my manual book for my IOM Pathfinder 3 & I can't cut it on I need help...THANKS IN ADVANCE
完成的
Thank you for your thought and I will going do that as possible because I need my speaker for tomorrow it's 4th of july
完成的
显示更多的1条评论
添加一条评论
Hey, I fixed my problem!!!!!!
So, I have had the Wismec Active as our sound system for the vape shop I work at, as it helps to sell the mods. Mine JUST stopped working. I peeled off the silicone protector and down by where you would plug it in to charge…..there is a hole and just under it the letters RST. Take a sim card pin (I used mine from the Ifixit kit I bought from ACE) or other small pointy object and press the reset button for five seconds. Voila! It turned on and started connecting.
Peeling off the silicone will not harm the mod, it will go right back on. Just make sure everything is centered on the buttons and stuff.
Happy vaping! <3 M3D1C
这个答案有帮助吗?
得分 2
1条评论:
Thanks it worked like magic.... I truly didn’t want to lose this vape
完成的
添加一条评论
Hi I have problems with the speaker because I took it to the park and it rain the speak got wet it’s been over a week trying to fix it the power not turning on what is the solution? Can someone help me please?
这个答案有帮助吗?
得分 0
1条评论:
When I connected everything it worked for 3 mins then went off I can't get any sound out of the speaker's it won't even talk now any body have this problem
完成的
添加一条评论
添加你的答案
Mason Hollander 将永远感激不已
浏览统计数据:
过去 24 小时: 13
过去 7 天: 63
过去 30 天: 240
总计 132,135
